changing oil on the weekend, keep a healthy Z :)
1) going to drain oil, and new filter, how many litres of oil do i put in?
2) where is the factory oil pressure sensor? want to plumb my GReddy gauge in,
got a T piece, asume its by the oil filter somewhere???
and is the thread 1/8 NPT ? (most jap cars are)
3 litres of oil do??
i guess nobody knows the standard oil pressure location.... ?
get a 5liter can...you wont need it all its under 4...pour it slow keep checking the level..fill the filter up before fitting...takes quite a lot
Edited by Uno
Cheers. :)
il have a look for the standard oil pressure sensor while im unbolting the sump plug
oil pressure sender is on oposite side of engine to oil filter, cant miss it. not sure about plumbing other bits into it though be intersted if it works!:D
dan.:)
dan.:)
thanks mate :)
will let you know, hope the weathers fine!
