Signal Wire
I've just started to fit a KPH to MPH converter. I've removed the clocks from the car and exposed the loom / plugs.
The instructions that came with the converter say the signal wire should be either L.Brown / Blue (white connecter, right row 2nd from bottom) or Yellow / Blue (centre connector, 3rd wire).
This doesnt match with what I have. Are there different coloured wires in the looms for different year of car?
If so, what colour should the signal wire be on a 1990 car.
How do I confirm that the connector is the right one?, as one should be a white connector the other is the centre connector.
Is there any way to prove, test or trace the wire.
Assuming you have a Series-1 speedo, you cut the wire that goes to the "Pulse In" shown on this photo:
Yup, its a series 1 TT. I'll wait for the black clouds to pass and have another look.
Cheers mate.
Oh, just another quicky. The "+" feed for the converter, does it matter where the feed is taken from?, or as long as it is a switched "+" and not permanent it doesn't matter.
Woohoo, it works!:hyper:
Cheers for your help Graham.
Call me a nutter but i drove mine and had a friend touch the signal wire on all the other connections till the speedo worked haha.
YOU'RE A NUTTER!!!!
:p
