vibration through steering wheel
Ongoing...................
I've discovered a vibration from about 40mph upwards through the steering wheel which gets worse the faster i go.
So far i have:
Changed the tension rod bushes to poly ones....no difference.
Checked each individual piston in each caliper is working.....yes it is.
Had the discs checked for warping......slightly out on one worse on the other had them skimmed..........still no difference.
The car is now at Power Engineering who skimmed the discs and they are doing further investigation tomorrow.
They've also checked the wheel bearings and both fronts are ok.
Anyone got any other ideas???????????????
Cheers Alex
07944045178:headvswal
So far i have:
Cheers Alex
hi alex
i had the same problem with my 300.
checked every aspect of the car, all bushes, all rods, all control arms, etc.........
turned out to be the wheel balancing!!!!!!!!!!
only a few grams out, got them done and it was fine. was scratching my head for weeks!!!!!!
check the wheel balance with a good company.
alan
Could just have thrown a wheel weight, only needs to chuck a 5g bit and that will cause it too wobble, not as noticeable at higher speeds as the wheels virtually self balance. But between say 25-45 would.
I know mine vibrates at 50MPH for a second but that is because of the prop shaft bearing (or something like that im not expert).
You won't get vibration through the steering wheel if it's prop related.
Tell me about it and that's what i thought Si, the company seemd to think the prop shaft was something to do with it and when i mentioned upper and lower links and bushes they wanted to check the run out on the hub???????
I wish i could find a garage in London i can trust that really has some knowledge of our cars.
I do need to check the two bolts on the other end of the torsion bars because when i put them in i tightened them when the car was on jacks and should have done it when the car was on the road....
Maybe i should also check the geometry????
Sorry my fault didn't read the thread right, my vibration is the car not the steeringwheel ;)
