oil droplets
its been raining, when i park the car theres oil om the floor.
and if i move it a few meters forward, and go back, it appears again.
so sounds like its doin it bad :(
any suggestions? il get a tidy mechanic on the scene ASAP,
clean the engine, wipe all the oil away, get underneath and see if you can see exactly where the oil is coming from ..an oil leak doesn´t always have t be something drastic..could be a cracked or brittle pipe or a loose connection.
is it front of the engine, back, middle, it could be a number of things, i.e, rocker gaskets, sump gasket or even as simple as a new o-ring is needed for the sump plug, or it could be what i had which was a loose turbo elbow which spat oil out every now and then.
ok cheers guys,
il make sure its toppt up with oil until i get a tidy mechanic on the scene :)
