Poll: Which bushes are you using?
So which bushes have you installed in your car?
Whiteline
Nismo
Energy
Driftworks
Solid
Stock
pick a mix
Which bushes have you fitted 13 members have voted
  1. 1. Which bushes have you fitted
    • Whiteline
      0%
      0
    • Energy
      30%
    • Nismo
      15%
    • Driftworks
      7%
    • Solid
      15%
    • Stock
      23%
    • Pick a mix
      7%
    • What are bushes?
      0%
      0
Enery Suspension bushes for :
Anti-Roll bars and droplink
Steering rack
Rear subframe
Rear Differential
Rear multilink hub carrier
Nismo Gearbox mount
Solid steering coupling bushing
SPL brass bushings in the gear shifter
Rose jointed Adjustable arms replace any remaining bushes
hmmmmm now me:
Energy:
anti roll bars and drop links
rack bushes
rear diff
Nismo Gearbox mount
Lower gear shift bushes are... erm.... plastic i think, but i did change them :D
Driftworks
front Transverse arm bushes
Rear Tranverse arm bushes
rear hub carrier bushes
The rest with adjustable rose joints
Powerflex all rear hubs and small traction arms whiteline subframe locking rings.
I didnt think powerflex manufactured them for the 300zx?
Yes they do there a purple colour most nissans have the same bushes s13/s14/r32 etc.subframes almost the same.and hubs.:cool:
Got rid of a lot of my bushings. Suspension has rose joints on the tension/camber arms. Rear subframe has locking collars and the steering rack has PU.
Has anyone got the Energy Suspenion Polyurethane Rear control arm bushing set fitted ? (18 bushes...replaces all the ones in the rear hubs and rear arms).
Want to know how it affected ride/noise ?
Im having adjustable rear arms with rose joints, but that will still leave 4x ES bushes in each hub to replace and 2x in the lower wishbone. I heard the ES ones are very harsh for the rear, and Nismo are a better ride ?
I got driftworks ones in the rear and omg were they tight... i think they are a slight oversize so makes the arms solid no extra noise though. But much much firmer.
are they polyurethane ?
yeah... they are.
£8 each but they are tight to fit and need a good push.
