how easy, ive noticed that my rear brake pipes are slightly corroded
are they an easy job, they look a bit akward, may just pay someone to do it, could they be rerouted to make them easier to replace
depends if its front to rears or the ones that go across over top of the axle. if so easiest to drop axle.
Or you could contact Mac got all mine done for a very reasonable price last year:bow::bow::bow:
They could be rerouted aslong as they dont foul on anything .You can get a flareing kit from machine mart for about a tenner and copper pipe and a tub of 50 nissan ends from most motor factors/ partco etc .I done a few pipes on my old s13 not too bad a job.
Im not sure if you have to remove the subframe to get to the rear ones but if you can get to the ends too undo them you can cut the rest out. You maybe able to reroute them diffrently aslong as they are attached properly and dont foul anything youl be ok.
