How big can it go?
I believe a 92mm bore will give you a 3.2 engine, and I would'nt want to push the limits of the cylindar wall thickness beyond that.
A stroker kit you get it up to a 3.4 but you talking £6-8K just for parts.
are you looking into potential NA power increases ?
Just weighing options, the engine's reaching 85k so i'm considering a full rebuild with ported heads and overbore.
I'd love to see a High power NA VG30 build in the UK.
- Bigger displacement
- Increase compression ratio
- Headwork
- Solid Lifters
- Aggressive Cams
- Bigger headers
- Bigger injectors
- Lightweight pulley/flyhweel/propshaft
- Maybe ditch the plenum and go with individual throttle bodies
A powerfull, responsive NA engine that revs towards 9k rpm :hyper:
You'd really want to shove it in a Lightweight NA slicktop shell to make the most of it and have a Track screamer.
I want to keep it road friendly though, so i'm torn between a SWB slicktop and my 2+2 targa.
Either way, i want a fast N/A
- Headwork
- Solid Lifters
- Aggressive Cams
- Bigger headers
- Bigger injectors
Tempted, i've been looking for a project!
Shunter is looking at doing this.worth having a chat with him.
