Dinitrol RC900
i can highly recommend this stuff... imo a much better product than waxoyl. i use the same brand (dinitrol) on airbus and boeings, allbeit a different spec and the military use that very same stuff on all their vehicles.
if you going to attempt to protect your car yourself i would recommend going for this rust proofing kit which includes eveything you need including the RC900 in aerosol form or better still, if you have a compressor go for this kit...
cheers joely....do you think just one tin of rc 900 tin is enough for a zed..?
regards
chris
Top advice joel, cheers....been intending to get mine done before she takes her 1st steps. :cool:
regards
chris
the RC900 is basically a rust converter... you will apply it to rusted areas before applying your underbody sealant or cavity wax... so basically, if your car is a uk spec... get 2 :rofl: otherwise im sure 1 will be sufficient.
  • 5 weeks later...
used it yesterday....very good stuff easy peasy to use covers very well helps if you can get the car up high and if your on your back for this i recommend a mask or you'll be rust proofing your tongue :tongue:...i did all the relevent bits under the car and still have almost half a can left :D
Have you done yours ? If not we could have a bit of a joint-rustproofing day ...
that sounds like a top plan ;) iv been planning to do it this summer at some point... have you got a compressor? we could buy a couple of these kits and get up on your new fang dangled ramps ;)
Yep, got a compressor, just building up to spending that much on some ramps !
