Lights quick question
Hi,
(Here i go again..) I was checking the lights out last night but i cant seem to get a set to work. Can someone explain what lights should work on which switches/dials..
Looking at the main cluster of lights on the front, the small circle lights come on but i cant get the oblong ones next to it come on. Rear lights seem to be working (i have got the red light warning on, on the dash but i know this can happen after a UK light conversion...)
someone fill in my chart please!
side-lights - oblong in bumper - dial pos 1
normal/dipped - - dial pos 2
main beam - - dial pos 3
fog - - button
(also what is the forward position on the indicator lever for? - there seems to be 2 modes but i did no notice a difference when using it?)
Thanks Again!
Barry
the mbig oblong ones are your full beam, they should come on when you push the indicator stick forward (i think never used them though and can't remember not sitting in the zed)
The small round lights are the normal driving lights and the larger section beside them are the 'Bright' or 'High' beams. Pushing the indicator forward should activate the 'High' beams. If it does not then this is another thing to have repaired on the car. Perhaps bulbs are needed?
The normal driving lights are notorousily dim perhaps you should consider either upgrading the bulbs from their current 55 watts to 100 watt bulbs or the JeffTT Bacofoil upgrade. It made a real difference on mine with the 100 watt bulbs in.
You can find more info
here http://www.zedworld.co.uk/wizzm.html
and here http://www.zedworld.co.uk/wizzn.html
