Seatbelt Retraction - Factory Fix
All credit for this goes to Gazza on Aus300ZX.com/ I tried the fix and can vouch for the diffrence it makes.
The full post can be found here.
As a lot of us know, the seatbelts in the zed can stop retracting properly with the result of the latch plate getting caught in the door and causing damage. Ive found that this is not just a problem with the 300ZX but most Nissan cars and there is a repair kit available from Nissan.
The problem is with the D ring (the top seatbelt guide) providing too much friction, either from dirt accumulation or the material itself so Nissan in their wisdom have produced a kit with fluorine tape stickers that reduce the friction and prevent dirt buildup. In this picture you can see the buildup on my D ring.
Contact your Nissan dealer for part number 87880-79900 you will receive a small bag containing two stickers and a short length of fine wire, enough to do two seatbelts.
The tools required to do this job are a 14mm socket with ratchet, a torque wrench capable of providing 50Nm, one or more clips/pegs, cotton buds and metholated spirits. A high pressure cleaner can also be useful for cleaning the seatbelt but you could soak the belt in a bucket instead.
Once you ahve removed the seatbelt upper mounting, clean the D ring by threading the supplied wire through the slot in the D ring and scraping the buildup off. I scraped off a lot of dirt plus a fair bit of plastic shavings/particles, no wonder it was having problems.
Slide the sticker through till the sticky side has just passed through the slot (or it will be very difficult to peel the last of the backing off) and once squared up, stick the tape down to the D ring loop being careful to lay it flat with no ripples or bubbles. Take your time with this as the sticker can not be peeled off again once stuck down without ruining it. This part is a major PITA
Once finished, the repair job is barely visible
Sounds like a easy fix, I get fed up winding mine back in all the time, I just checked on the courtesy site and the part works out at £2.09, think I'll add it to my next order.
I fixed mine without even having to buy that. I cleaned the webbing down and then used a silicon spray on them. Wiped them clean and now they fly back into the reels. I might give this a go though too. :)
What silicone spray did you use Si? :)
Nope, nothing. It's not as good as a new car, but they certainly feel much better.
Warm soapy water. I left it to dry though. I did it when all my door cards were off.
