Has anyone who's used one of those large 1 farad capacitors for a sub amp noticed a difference?
Vijay
I've not used one but I understand that they are used to store electricity in very high powered systems to ease the load on the battery etc.
I stand to be corrected as usual.
"I love to go down to the schoolyard and watch all the
little children jump up and down and run around yelling
and screaming. They don't know I'm only using blanks."
Emo Philips
no, I think you're correct. But am I better off just getting a bigger battery?
Vijay
Dunno matey I suppose it depends on how much current you're drawing to kick the sounds out.
I was looking through a car accessory mag last night and saw this beast of a battery...1000 cold cranking amps deep cycle marine jobby and you can get them with 4 terminals aswell!!! Absolute mother of all batteries. wink.gif
Emo Philips
A Cap will store power at about 13 volts, should your battery not be able to supply then the Cap provides what`s needed. Only called for in larger set ups but get a volt metre on your amp and crank it up, if you are drawing many powers then get one.
