intake manifold removal????
Started to removal or attemp to remove the heads on my N/A and got stuck removing the intake manifold. I have removed the bolts ect but when trying to remove the part of the manifold closest to the rear of the engine wont budge. There are two pipes that are moving when trying to remove the intake, I expect these are connected to the intake manifold and that its these that are stopping it from coming away. If this is right how can you remove these pipes, and any other help on the removal of the manifold will be very much appreciated.
im sure they are very similar to the tt heads you will find a small 10mm bolt at the rear of the heads nearest the bulkhead it bolts through the rear of the head into the block :D
