Battery chargers?
Need to get myself a battery charger as the Z is always going flat sitting on the drive for months on end.
I've borrowed a couple recently but the fuse immediately blows and I'm guessing it's down to the size of the huge Bosch battery I've got and it needing a high current to get it charged.
Anyone else had this problem?
Thinking of getting one form Halfords tomorrow but not sure if theirs are up to the job?
  • Replies 27
  • Views 1.2k
Thats sounds like it could be a dead battery not holding it's charge.
This Black and Decker charger wasn't exactly cheap at £53 but it does various battery tests and even has an alternator test to monitor it on and off load.
Starts off charging at 10A then drops to 6 then 2 as the battery recharges.
You can then leave it permanently connected and it will just top it up as and when it drops.
I was about to bin an expensive battery after trying 2 other chargers but I'm glad I paid the extra for this piece of kit.
I've got 2 cars and a boat so always swapping flat batteries around.
Should have got one sooner.
Yep thought about it after I posted and came to the same conclusion, tested it by charging it up with the daily driver and found the charge dropped of once disconnected, the battery is only a year old but has not been getting recharged..... need to see if ive still got the reciept for it.
Still its save me old charger from the bin :D
