rough idle boost pressure high
my idle smooth to i blip throttle then runs rough boost sits high then when rev a little boost go,s down b4 up and when running crap can take leads off some spark plugs and runs the same
ok from what ive managed to decode from your sentance....
ย
Check that the coil packs/connectors are ok - do an ECU fault code check, search on here its been mentioned plenty of times.
ย
-Stu
you have already started one topic on this and recieved replies to it... Why have you started another one?
just noticed you posted twice - and what ive said has been mentioned.
ย
Mods delete this one?
ย
-Stu
ย
ย
-Stu
ย
already told him the same kinda info about a hour ago :D sounds like a fcuked coilpack :nelson:
ย
200sx ownership helps prep you quite well for Z ownership doesn't it? lol :)
