Im losing brake fluid in bucket loads, did 7 miles this morning and got through most of the reservoir !!
Are there any 'comon' places the lines fail etc???? Before i have to trace the brake lines.
Can't see any fluid around the reservoir etc
  • Replies 60
  • Views 1.2k
Almost, ABS last as its closest to the BMC ;)
General concensus is that you start with the furthest away from the BMC and work your way to the closest. This would give FL, FR, RL, RR, ABS front and rear.
Bleeding the ABS unit is simple - there's 2 bleed nipples on top of it. Remove the cover in the boot, lift the rubber matting on top of it and you will be able to see them :)
Right will follow above instructions, cheers Andy;):D
sorry i thought u did it furthest from the master cylinder
Your forgiven;)
both will work, it will just take a bit longer the other way :D
Was wondering what the difference was,lol
Your basically filling the system/pipes/resevoirs with new fluid and to do so you must remove old then fill with new by pumping it through with brake pedal and pushing out all the air so the system is filled with only fluid.
Have bought a second hand BMC from Z World, will have it friday :)
how much fluid am i gonna need ???
No more than 2 litres I hope cos thats all I got
My Dad just worried me by saying they normally they leak into the drivers foot well!!!! ARGHH hope not as im not gonna be near my car till tomorrow eve!!!
Crotchy what dot you got in there? u gota match it. or just flush out the old and put some 5.1 in there mate :D
i cant remmember how much youl need.
try the online manual.
you really need to clean all the fluid away with water to prevent corrosion that stuff will sort out your paintwork in a few hours.
Right done mine and much better, can actually stop fairly sharpish:Dthanks for all the advice guys:duffer:;)
Already!!!!
Already!!!!
I dont mess about, need brakes for saturdays track day:nana2:
she the man dont ya know......
:D
track day???? can i sit in the passengers seat? i have a big helmet you can use.
Sorry already got a passenger(wow300) and already got a helmet;)lol
i didnt wanna come anyway :(
Ye you did,lol...I am sure there will be some vids posted after so you wont feel left out;)
