Hi
Just a thought but, it may be an idea to condense all the parts from other cars that go onto a zed into one place!
I will start the ball rolling
Skyline GTR R33/R34 front and rear calipers and discs
Nissan 350z front calipers and discs, I know the rears fit but need modding can someone explain further? AndyP?
Nissan Terrano MkII exec spec chrome interioir door handles
Renault rear wiper, again not sure what model?
  • Replies 70
  • Views 18.2k
200sx S13 Aftermarket adjustable arms -
Front tension arms
Rear Upper arms
Rear Traction arms
isnt the Escort RSturbo rear wing a cheap alternative to the 99 spec
so is a length of 4x2 wood, but neither actually look like a 99spec spoiler LOL
Front tension arms
Rear Upper arms
Rear Traction
I thought I read somewhere that there was a little trouble fitting the front tension arms?
Front tension arms
Rear Upper arms
Rear Traction arms
very true I wouldnt be seen dead with either on my car:tongue::rofl:
Hi
I think ive read somewhere on here that both the S1 and S2 Laguna wiper arms fit
pretty much any rear wiper will fit, they all use the same motor fitting...its just down to style really.
Primera P12 from 03 onward is the same as the Laguna rear arm from a MK2 (MY00 - 08)
That's ok, you have a single baked bean can on the back of yours. :p ;)
Infinity J30 throttle linkage covers.
only on 94 onwards Z32 because of scew holes in the different plenum design (apparantly)
primera heater matrix, with a small modification to the heater box (needs dash out method to do)
This would be a pretty good FAQ ;)
What yea/model DC?
If anyone can if they have the info, give the year/model that would be cool:hyper:
What yea/model DC?
this one for example
1990-96 Primera, it has the advantage of being a copper core rather than steel so should last longer aswell ;)
-Nissan Sunny/Almera/Primera doorlock hinges fit the Zed
-R32 GTR upper rear control arms (also most upgraded ones) fit the Zed
-Tomei GTR solid lifters, valve springs, retainers and shims fit the Zed
-R33 crank and cam seals (also the N1 ones fit)
-350Z/VQ35 Powersteering pump fits with slight modifications
-350Z/VQ35 Oilpressure sender
-(Nismo) R33 GTR gear box mount.
-R33 GTR accelerator peddle (has a bulge at bottom for heal toe)
-Zed,R32 GTR and R33 GTST have same gear box (the center section with the gears)
Cool,
Forgot to say the 350z pedals fit the 300 as wel, with a slight bit of modding!
Has that been welded Andy?
Yup. Although I think those were Eric's pics rather than my actual hubs, but they look identical obviously.
