wing side repeaters easy to change?
Wanting to change wing side repeaters and front bumper indicators. I can do the front bumper ones they are easy I've had those off already to remove some condesation in the ones I have and seal them up. Never took the wing repeaters off though are they easy to do? Mine are all faded orange and look a bit rubbish :cool:
  • Replies 30
  • Views 1.2k
Easy peasy :)
Just ease one side out (small slotted screwdriver maybe - be careful) and they'll literally pull out :)
just hold the repeater in your hand and slide it toward the rear of the car. The front of the repeater will now pull out so slide it all forward!!
mmmmmmmmm may get me some of those then where do I place this slotted screwdriver ? between the rubber and the lens?
Try the other suggestion first (not the wing off :rofl: )
If that fails then you need to get the screwdriver in between the rubber and the wing (be careful).
But seriously its easy :)
I will have a play tomorrow I crap with cars ...give me wood, laminate ,ali or most other building material I can make anything cars are not my forte I can do an oil/filter air filter change anything else I will successfully break
The wings need to come off :rofl:
is that the bingo wings? :D
Seriously bud, its seconds of a job :) You don't need to know jack about cars, if you did, i would'nt be able to do it :rofl:
I shall experiment within the daylight hours of the next day :D
they're spring loaded into the wing, as said push the repeater to 1 side and then it just pops out, easy peasy lemon squeezy
Nah bingo wings are on the weight saving mod list. :D
remove orange bingo wings for aerodynamics and weight reduction :rofl:
If you are buying clear ones some dont fit the existing bulb holder the bulb holder has 3 locator's and the lens only 2 just remove one of the locator's from the bulb holder with a sharp knife and bobs yous mothers brother
noted cheers clears I'm after will now scout the land they call the bay of e for some new toys
Engine out job im affraid, Oh and the rear sub frame has to be dropped to release the wiring loom hehe....
thats about the ONLY job i can do on a car is change the side repeaters!
now ordered the side repeaters but not gonna bother with the crystal fronts as they have holes for sidelights/fogs or whatever. Its a jdm and have the glass ones at the front already so i'll be left with crytals with blatent holes in beside which they are probably a bit clear against the glass one even though they would match the headlights ok
Yeah thats right, but i'm gonna stick some foil over the holes when i get my car back :)
came today and they look much better than the faded orange ones
