The Update thread!
Thought I would start here as today saw the 'offical' start of the Cossy conversion!
Done today,removed prop,tank,engine and cleaned the bay up a bit for painting.
The pics!:cool:
Soon ready for a trial fit of this,all decatted an' everything!
I was hoping the Scorpio sender was going to fit my tank but no!-the sender resistance was wrong and the flange to big,so I came up with this 'hybrid'-my sender with the Scorp' pump fitted,sorted!
Watch this space.....................................(again! LOL!)
  • Replies 105
  • Views 5k
Working to a timescale here guys!! LOL!-might not move for a month or so but at least it'll be done!:wack:
Well today I attempted the wiring!-don't look like I got much done but all day and managed to get starter,alternator,main earths etc in.
tomorrow I have just got to wire in the fuel pump relay and clip everything up,should have seen her running tomorrow but some dope forgot to order a fuel filter!:wack:
Getting there............
Nice one Daz and good work, that'll be one quick MOFO of a Tranny, but if it were me I would have mounted the ECU (if that is what it is on the bulkhead) the other way up, stop water getting into the cables and connector ;)
It IS the ECU mate and I also would like it around the other way but seeing as it says 'this way up' That's how it ended up! Was going to put it in the cab but meant extending the loom/more work,so will probably make a rubber cover for it!:cool:
:nelson: :cool: :bow:
well finished the wiring today,kept hold of the relay holder from the scorp' and it makes a neat job!
Also got the fuel filter so that was fitted.
And SHE RUNS!:dance:
Started making up an exhaust today so that should be done tomorrow!;)
:eek: :eek: Fook me, you work quick :D
LOL!-don't I know!, I'm knackered!:wack:
when i win the lottery, im employing you to fit me an r35 engine and running gear in me zed lol, will pay ya above the minimum wage lol
You gonna bring it over to Spain then? LOL!
hey i will have won the lottery, i will take it anywhere lol
Got the exhaust done today,not exactly powerflow but it gets me going! LOL!
Had to fetch a petrol tranny prop from the breakers(bottom) as the scorpio as a 'doughnut' (Middle) got to take this tomorrow to be shortened and that's another job done!
Where did the week go!!??:wack:
I cant believe you have converted a trannie into a cossie within a week :O Very nice work
Cheers mate,not quite there yet,got to fit gear selector and make linkage,plumb in the cooling (waiting for a rad) fit a transmission cooler and a bit more wiring when the selector is fitted (inhibitor) so a couple of days hopefully!:smw:
Depends how long I'm here!
Well I got the selector fitted today,might need extending but need to drive it first!
The linkage is a pain,reckon I need to use a cable!:headvswal
Also had the prop done today,2 hour turnaround,new bearing,shortened and balanced!-that's service!
As usual, slowing down now waiting on people(parts) but happy with the progress:smash:
Vinz-'Slappy' has been doing his bathroom, he don't rush! LOL!!
You sure I'm not boring you Brian?;)
As you might have guessed,Iv'e been back at work so progress is slow! LOL!
Today got the gear cable sorted,wired in reverse lights,speedo,inhibitor etc,throttle cable and fitted the prop back on! Also sorted the air filter,just need a radiator now but doesn't seem to be one in the country!:smw:
not very clear but this is the cable set-up,
Soon be test run time!:D
