injectors
Yes you do.It will run without them, but not well.I believe it affects the spray pattern.
You need to be looking inside the fuel rails, to see if the busted up parts are there, or whether they have now dropped into the engine.
Mine had broken into 3 bits+ i retreived bits from rail with a long match covered in vaseline.
If they have gone onto engine, you just have to hope they will be thrown out when it goes,unless you can remove them somehow.
afaik, courtesy nissan are the only people to do these....cheap as a cheap thing too, get too many as they are a tight fit.
yeah il be needing a couple of those soon too. coutesy nissan do them for about 5 dollars i think or was it 12 dollars and 5 pounds?
Get more than you need, i cracked the first one putting it on, they are a very tight fit.
2nd one was a Lot easier to do with a drop of grease.
Try soaking them in boiling water and that may make more supple?
sounds good enough to me.... or even a few seconds in the oven....
Not the oven it can get too hot and it also burns/shrinks the plastic!
ok not the oven, how about the steamer?
haha
i wont burn if its on 70c
