MAF Upgrade
Is there any MAF upgrade available for a TT, can you fit a bigger one off another Nissan for better airflow?
300zx maf is an upgrade for the 200sx
But I dont think nissan made a maf system that could handle more than the 300zx one
You need to get an aftermarket afm system if you want to go bigger in that direction
Anyone know what the highest power output has been got using the stock maf system?
you could wire a q45 maf up which is massive but tbh if you need to go down the route of running a higher output maf then you should be thinking of going for a map setup anyway ;)
The car will have a new ECU for the new set up, I just wondered if a standard MAF was good for 600bhp or it there was an upgrade available?
After about 450-500hp those that dont go for a MAP setup go for a Twin MAf setup instead
So with a new ECU/Map then the standard will cope?
when i say MAP i mean an new ecu which uses a MAP sensor and gets rid of the MAF LOL confusing i know
Mike
Mike
Got it!!:D
Got it!!:D
then the new ecu would need a fuel MAP :D
i ran the AEM ecu with a 3.5 bar MAP sensor, much easier when building a high power car
