Main beam....
Hi all,
I thought i'd post this thread, just in-case this has happened to someone else, or is another common problem and before I start stripping it all to bits.
I flashed my main beam at a guy who let me pull out yesterday, and now the main beam is constantly on when I switch the lights on.
I am assuming the switch inside the indicator/main beam stalk has bust, or is there a relay or something elsewhere?
Has this happened to you?
If it is the switch bust, does anyone out there have a unit for sale??
Look forward to hearing your replies,
Chris.
Hi all,
Chris.
there is a relay in the engine bay fuse box , more likely to be the relay
[sIGPIC][/sIGPIC]
check you fuses bud :cool:
regards,
alex
Cheers guys....Appreciate the quick responses!
Will check the relay.
If you turn on your head lights and all you get is the main beem, then your fuse has gone, i had this when the fuse in the foot well went. i'd start with that..... i think it's a15amp one on the top row.
Neil
Neil
Happened to me, it is defineately a fuse in the drivers foot well :)
deffo a fuse its a 10 amp and its the 3rd 1 on the top row, well i think its the 3rd 1, its been a while, lol
Cheers for the diagram Scotty, and all your replies guys.
Just changed the fuse....proper job!
Thanks again,
Chris.
