March 21, 200818 yr Hi chaps, I find when the car has warmed up n I boot it a little, by the time its running at normal/warm temp it is not as responsive. It has higher rpm i (1000ish) and no error codes, def is not detting when warmed up. when I rev it it also takes a fraction longer for the needle to drop! any help would be great. Thanks G
March 21, 200818 yr Check the following (think all the how to's are in the FAQ storage area on here): TPS setting Base idle Base timing Also worth cleaning the throttle bodies and blast some carb cleaner in the idle valve BEFORE setting the base idle :) Cheers, Andy
Hi chaps,
Thanks G
