Boost Pressure
What sort of boost pressure can you run with wiseco pistons fitted and standard head gasket and rods, is 12psi ok?
If I want to run 21psi are we talking eagle rods, wiseco pistons and cometic H/G.
Obviously there will be different management, 550cc injectors as well.
  • Replies 33
  • Views 923
So.............. if i have
reconned turbos (360thrust and step gap pistons)
wiseco pistons
new bearings
new HG
new uprated valve springs
550 injectors
exhaust decat
induction
and ecu upgrade i should see what kinda bhp safley
US or UK? :rofl:
US or UK? :rofl:
hay just because your running silly power no need to pick on the smaller boys :(
I am not LOL but there is a difference between the two :slap:
Which Z1 tubs did you go for John ?
He went for,or i talked him into :D the gt500s which are very much like the jwt sport 500s.
wiseco pistons
new bearings
new HG
550 injectors
exhaust decat
induction
Well with that lot you should see almost 400bhp maybe more with new valve collets :D .
wiseco pistons
new bearings
new HG
550 injectors
exhaust decat
induction
i know them valve springs wont give me more bhp but i like mentioning them.
Out of curiosity,
My set up used to be :-
Stock tubs, injectors and zorst, JD chip, Apexi filter and 1.2mm boost jets running at around 13PSI. I then fitted 1.0mm boost jets and got around 15PSI but got dett at high RPM.
My set up is now :-
as above plus, Divorced wastegate down pipes, decat, powerflow cat back and OS Giken Twin Plate Clutch and Fly
My question is, would I still get dett if I refitted the 1.0mm boost jest or do I have an underlying problem ?
CheerZ
Paul
I forgot to mention, I also have uprated SMIC and I think they are TRUST, would that make any difference ?
