conzult help
as above i need a bit of help with th conzult as is keep saying to conect the cable....i got a blatz usb cable. is there different conzult for usb and com?
:dance:
ime sure conzult is only suported via seriel mate ;)
it will run usb but i think it is fussy over the usb converter
[sIGPIC][/sIGPIC]
The blatz cable wont work with conzult. Conzult will work with a usb convertor as long as you have the correct cable to start with.
is strange cos it runs fine with the freeware version...
ย
I've already responded to your PM regarding this subject but for the benefit of those watching this thread:
ย
Our ConZult interface/cable is INCOMPATIBLE with the Datascan software that accompanies the Blatz product. The Blatz cable (and any other cable found on ebay) is INCOMPATIBLE with the full version of the ConZult Diagnostic Software. However, there is a freeware version (ie a very stripped down version) of the ConZult diagnostic software which WILL work with the Blatz cable.
ย
DTA-Motorsport will NOT offer any technical support on equipment and software not officially sold by us or our resellers. We therefore suggest that to obtain the full benefit of our diagnostic software you purchase the FULL ConZult Diagnostic Kit.
ย
Our ConZult equipment works through both SERIAL and USB connections. For the USB connection to work you need to purchase a separate USB-RS232 converter from us. This converter contains the correct chipset to deal with our bi-directional data flow. You will find that if you connect the ConZult interface through any other USB converter that the software is likely to freeze and/or crash. You will also require the latest version of our diagnostic software (ie v2.4) which is optimised for use with our USB converter.
ย
ย
Dan
