- Replies 51
- Views 1.5k
- Created
- Last Reply
j1mmytt 20 posts
markzx 6 posts
EvoluZion3 5 posts
TopLess 4 posts
How many people on here have experience with these pistons?
They are going inside my rebuild.
Scott at nexus said hed rather fit pistons that he has tried and tested, he wouldnt like to fit them as he doesnt want to hurt his rep if they blow. Thats fair doos but im not looking for massive power gains just a set that can handle at least 17psi.
Im rebuilding the standard tubs myself and getting them balanced and having bigger injectors fitted at a later date.
I read recently max psi on oem tubs is around 16-17 am i wrong?
Also its debatable on which headgasket to use, oem or an uprated metal one, i heard uprated are more prone to failure, legrath you mentioned using a stock one.
I cant decide on these two options
help...
What are you lot using then?
