Rear strut bar template
Does anyone have a template (or ideas) for the cutting of the rear panels when fitting the strut bar for a swb?
what i did was put the mounts on and left the bar off. re fitted the plastic covers and thumped them where the mount hits., this leaves a mark on the underside and then i use a hole cutter to cut out the right size hole
Thats magical! I was wondering the exact same thing!
What brace did you fit? I was looking at the Cabring one off of z1.
Same method used here.
"what i did was put the mounts on and left the bar off. re fitted the plastic covers and thumped them where the mount hits., this leaves a mark on the underside and then i use a hole cutter to cut out the right size hole"
