Water pump change on a auto 300
Does any one know how to stop the crnk from turning on an auto box when trying to take off the bottom pully. And please dont say put it into park :headvswal
i have tryed this method few times & it works, Get a breaker bar on the crank pulley nut, then try jamming other end near the ac compresser/crossmember area or any thing solid as long as the bar doesnt move, then crank the engine couple times with key should loosen pulley nut
hope that makes sense
needs to be "shocked off" as in impact wrench ;)
av heard of people having to cut it off before
All sorted now thanks
how :confused:
good stuff matey :nana2:
Erm belt wrap technique? :confused: Works EVERY time
Erm belt wrap technique? Works EVERY time
????????could you explain please
ya dont need to explain this to me duffers, you'll be doin mine :rofl:
AH HA found it the seach finger is your friend any houses going for sale near you Mr DUFF :bow: :bow:
Yep worked on mine too, even though the pulleys were all soaked in oil..
Well - it worked after I'd cleaned them with a lot of carb cleaner, then accidentally set light to the crank pulley twice trying to heat the bolt up :rofl:
