As per the "what did you do" thread I had to source a pair of replacement front calipers today, as mine have seized on the lower inner piston on both sides.
After searching the 'net, I found a couple suppliers had them in stock. First being Torquen - albeit at over £600 for a pair for either cast iron or aluminium.. Then I found some fully rebuilt aluminium ones (the correct fitting for a TT) at less than half that, which got me thinking. Cast iron vs aluminium....??
Both seem to have their merits and drawbacks - the ali ones being much lighter, so less unsprung weight - whereas the iron ones allegedly handle the heat better, reducing the chance of disc warpage. If one believes everything one reads on the interweb LOL!
Seeing as I don't track the Zed - and I am happy with the OEM set-up, when it works properly, plus I have a set of Brembo discs waiting to go on, as opposed to the Ebay ones I had previously, I thought the ali calipers would suffice.
Opinions please - good or bad😁
By
RichardS ·
Hello from Austria!
I read here, that some of you mean, the stock brakes are good enough
for stock-Z´s, and that improving the performance ist possible just in
"making a service".
My Z´s got around 350hp, I like to go fast, but I don´t drive hard, - don´t
wanna kill some unguilty ;)
But my last harder braking from around 120mph to around 60 made me thinking about purchasing a bigbrake kit (I like the Z1 most, still keeping the
original calipers). Discs started "rubbing" quite bad...
Got drilled and slotted Brembo-disks and metalmatrix-pads around...
So, how does a service of the calipers work, and why do they work bad when they are older?
Thanks a lot, don´t care about my bad english :mac1:
Patrick
