Few questions
Hi all,
I have a few questions hoping some of you may have some answers for me ;)
A mate of mine is breaking his R33 vspec and im going to fit his Brembo calipers front and back on my zed and would like to get sum meaty discs to go with them. what is the biggest size disc i can fit?
Also does anyone know or fitted wheels off a GTR to a zed.
If so are they the right fitment?
They are Rays volks 18" @ 9.5j
Dan
pcd will be the same it will be the offset that may be the problem if any
ive got GTR 34's front and rear, 330mm on the fronts and they hold it quite nicely, not sure of the rear size though, standard sized 34's
You'll want to fit standard sized skyline discs, otherwise you'll need to design and fit custom brackets to move the calipers out further.
Trouble with skyline wheels is they use the same width front and rears. 9.5" front rims are too wide for the front of the zed with standard arches.
Thanx for the info peeps!
So i have no chance of fitting these wheels then :headvswal
Dan,
I've got caliper relocation brackets available from stock. They're normally part of our big brake conversion kit, which uses Skyline 330mm discs, but can sell the brackets on their own. £80 for the pair, which includes two brackets, bolts and washers. Postage will be around £8. If you want some good quality discs have a look at my website: http://www.smithys-place/brakes.php and look at the DBA discs - very good quality and readily available.
Dan
