over revving
please can anyone help latley car has been revving to hi so when
putting into drive car is stalling when pulling away.
i have to keep foot on brake pedal to lower revs before pulling away.
:headvswal
might sound daft but have you checked the cable aint snagged somewhere.
thanks for help mate but its fine
I know what it is as it happened to mine years ago :o Its the plastic pipes on the top of the timing cover
my car also revs high but doesnt stall instead it launches when i put it into drive.
Could this be the same problem? do the plastic pipes leak?
its a big ask but could you possibly take a picture of these pipes so i can see what ones they are cheers
Its above you just click on the link
cheers pal and what did you do to fix the problem?
its in the link mate,makes a very intresting and potentially life saving read,and iff you aint got the time just pull them out and locktite or threadlock them back in using a few small taps with a light hammer
Oh yea didnt even see that link will check it out first thing in the morning cheers!!!!
ok just checked it out and they have not come out, gave them a bash just to make sure. Have you any over ideas as i have none lol. cheers
Car is now always ticking over at 1500rpm
Mine did this- stuck idling valve- back of engine on battery side- had to replace it- b of a job!!
If you look in the manual its the one with the slotted screw for adjusting idling- threads on here describe process but mine did nothing when turned so quickly obvious u/s.
Regards
Dave
