how long does your Z take to warm up?
Hi guys , just wondering how long it takes your ZX to warm up ,to the half way mark on the gauge?
ive only gotta drive mine a mile before its on the halfway mark so im wondering if i have a bad temp sensor, maybe thats why im getting saftey boost
:rolleyes:
  • Replies 27
  • Views 1.1k
when its cold i can usually get to work (6 mile journey) before it even starts to rise
mine takes about 5 mins
the standard nissan temp gauge is .........crap, get a decent aftermarket one , you will see that when its at halfway on the nissan one it really has a way to go on the accurate aftermarket one, plus the temp sender for the gauge is not the one for the ecu
mine takes about five mins to get half way ..how much coolant do you have in there or when was it last changed
course is not doh!
im having a blonde moment lol
Well to be fair, my black one don't take long to warm up at all really, 2 miles absolute max before the heater comes on. (I think that is 45c ish?)
what do u mean before the heater comes on? or do you mean before warm air come out?
well mine seems to take about the same time ,
i was suprised by how fast they warm up
Yes, the heater only comes on when the water temperature reaches 45c I think...
As I only have the stock gauge not an aftermarket item.
So when my heater comes on I know the car is not fully warm, but it's getting there (if that makes sense lol).
Rob.
Rob.
my heater comes on soon as i press the fan button or auto i think isnt that normal ?
obviously it dont blow warm right away though,
yeah about the same to 80c
I do find the stock gauge hits the middle when my aftermarket gauge is only upto about 40c! They are both running off the same sender too.
Takes another couple of miles to reach the normal 80c running temp. Even longer for the oil to warm up and thin out properly.
well i just went out in mine and it got to halfway up the gauge in 3minutes , and my heaters work soon as i switch them on
Just a couple of minutes - 5 when it's really cold outside (say below 3 degrees). Less than 3/4s of a mile after leaving home and it's warm enough for the heater to give hot air.
Richard :)
ive removed the aircon rad, so maybe it will take a bit longer for mine
Richard :)
thats about the same as me really , i dont fee so worried now , their all around aboutthe same amount of time
I think it depends on if you have also done a top end bypass, i.e., cut out all them pipes under the plenum. On my last Zed it warmed up in about 3 minutes, until I did the bypass and then it took about 10 minutes.
too many pipes , i gotta chech for a boost leak tomorrow, im dreading it :headvswal
One of the places people overlook is the intercoolers down the front, they can get damaged, or corroded or just perished pipework.
Cheers Zed i'll have a check
