265x35x18 tyres
Hi is any body using this tyre size on the rear i plan to fit fit them on my advan wheels there 9 j , I have rolled rear arches and a +35 offset wheel has any one had any rubbing problems with this size thanks taff. :)
I use these on the rear. no problems at all. I have not rolled the arches.
should be fine for you mate...
Yep i'm running that size on the rear with very low coilovers and never had any probs :D
HTH ;)
My car is fitted with Advans (see my rides) and 265 looked too narrow for the rim. Mine are fitted with 285's and can rub if cornering really hard. If you have rolled arches, I would not think you would get any probs at all. By the way. the 285's will give you better rim protection.
Yep i use that size all the time, and its the perfect size for the speedo to read correct.
I have them, not a single problem. Very common fitment those :)
Same as above,and above that, and above that, and above that.
Yep there to big, you could get away with 185 tyres :dance:
yep 265/35 is the way to go. :smash:
