February 21, 200818 yr Hi, has anyone got a pair of rear drilled disc's that they can take a template of the hole pattern, all I need you to do is make a rubbing on some paper so I can transfer it on to a drilling jig. cheers Paul
February 21, 200818 yr I hope you know what you're doing, if you simply drill them they WILL crack! You need to properly finish the holes, countersinking them and preferably re heat treating the disc once done...
February 21, 200818 yr You go paul. its good to see some diy mods going on here. why not. and if they do go tits up just an excuse to buy uprated ones :)
February 21, 200818 yr Author I hope you know what you're doing, if you simply drill them they WILL crack! You need to properly finish the holes, countersinking them and preferably re heat treating the disc once done... Hi Andy, thanks for your concern, but I have 16yrs racing experience Racing Trucks with drilled and grooved brake disc's and am well aware of what is required, they weigh over 5 tonnes and have a limited speed of 100 mph that takes some stopping. cheers Paul
February 21, 200818 yr ooooo if you get them drilled and they work il pay ya to do mine :) can you skim disks too?
February 21, 200818 yr i would never try to do this to standard discs, i read an article somehwhere that this is extremely dangerous, at the end of the day they are there to stop the vehicle and maybe save you or someones life one day, i wouldnt tempt fate
cheers Paul
