February 20, 200817 yr Hello Zeddrivers, I want to paint the black plastic inside the headlights in carcolour. Does anyone know the best version to "put the headlights in it´s single parts"? (don´t know the optimal words :wack: ) Someone told me, I get the glued parts opened with a heater (maybe the oven at 50 degrees celsius), but I don´t want do destroy anything. I don´t have any idea how the HL look inside (the mechanic parts) Can you help me? Thanks a lot, Patrick
February 20, 200817 yr Hello Zeddrivers, I want to paint the black plastic inside the headlights in carcolour. Does anyone know the best version to "put the headlights in it´s single parts"? (don´t know the optimal words :wack: ) Someone told me, I get the glued parts opened with a heater (maybe the oven at 50 degrees celsius), but I don´t want do destroy anything. I don´t have any idea how the HL look inside (the mechanic parts) Can you help me? Thanks a lot, Patrick Patrick, If you remove the headlight units from the car you can take it apart by undoing the various screws holding in the rubber. Then you need to heat the seal between the glass and plastic with a heater (a hair dryer will do). When the adhesive is warm you can CAREFULLY split the glass from the plastic by using some screwdrivers. Start in a corner and work your way around. Once you have separated the headlight you can remove the plastic insert (two small screws at the front) and paint it. While you have the headlight apart you should also clean the inside of the glass parts (don't forget the inside of the projector sphere). Good luck. Dan PS - I DO NOT recommend putting the headlight in the oven at 50 degrees C. You're likely to destroy the headlight and the oven will smell for a long time! ;)
Hello Zeddrivers,
Can you help me?
