Top Feed Injectors
Anyone ever fitted top feed injectors to thier zed??
I know they require custom fuel rails and such ...just wondering if its ever been done.
yes, I have done it using skyline topfeed injectors and it works fine.
it's a cheap solution, but won't win a beauty contest though :D
it's similar to the injector setup on the Z31, which uses topfeed injectors also.
The fuelrail is on top of the plenum, with small hoses running to the injectors.
I don't have any pictures of my setup, but it looks very similar to this:
hoses running from the injectors:
and with plenum installed , with the 2 fuelrails on top:
I take it the fuel rails on top are more or less straight tubes with spigots for injectors and feeds for fuel
Did you make your own rails ?
its a great fix if you want to go big power and fit say 1000cc injectors from a skyline :)
how did you fix the rails to the plenum eric?
Mike
currently with zip ties :D
but I'll have some fittings welded to the plenum so I can secure the rails better and it will look nicer :)
