my zed doesnt like to accelerate above 3500 rpm when cold, it will actually do it, but coughs and splutters and seems to be chocking up, it gets a bit better when warm but then sometimes when im sitting in traffic the revs slowy start to creep up to 2000 rpm, a quick blip of the throttle usualy sorts it out
there is a time when the engine is warming that the car runs perfect, it pulls like a train doesnt miss, doesnt backfire and feels correct
ive also noticed that if i drive home from work, it doesnt run correcttly for most of the way home, but if i switch off and leave it for a bit (maybe an hour) it runs much better if i g back out in it, im assuming that i may have a fault with the AIV (possibly wiring)
any ideas oh great ones
i never take mine above 3000 when cold
hmmm. thinking about it i never take it above 3k full stop
Sorry Allan I missed this earlier. Saz is right, don't over rev whe cold. Although it should still do it - check the ecu temp sender connections are clean
have checked the temp sensor, all seem fine, im not thrashing it, but taking it above 3000rpm when pulling out of junctions and so on is just a big no no, but as per previous problems, if i reset tps, ecu and so on, it wont do it for a hundred miles or so
have checked pkugs, timing seems ok, have checked connectors all over the engine, cant see or hear any bost leaks (although they may still be there)
am at my wits end with it
Just a complete off chance but have you tried a different ECU?
am gonna try the AIV connector at weekend, gona get rid of conector and try a couple spade conns and rewire it as far as i can, just a feeling im having as everytime i mess on with it, the problem is still there but is different in some way, if ya know what i mean
yup, i have a chipped ecu in ATM, will change it bacvk to my ecu at weekend, have had this ecu in for about a year, but ive had running probs on and off with my old ecu aswell
it will be something stupid that im not doingright, i think its electrical ratge than mechanical
  • 8 months later...
Hey Stella i know this is a long shot as it was a while ago but , did you find the source of these problems you were having as i am having very very similar goings on at the moment and it's driving me nuts....
