48 Refusals on MOT Beat that ....
Well ater my car was collected from SWZ, due to them making it worse than before it went in and before work was carried out to rectify by Zedworld, the old thing had a MOT to check what was wrong and failed on 48 points. Wow never knew you could have that many failure points lol. There are also about 10 other things that need to be rectified.
  • Replies 56
  • Views 2.7k
ouch :(
eek :( I had 16 failures on a Bmw once and cost me £1200 to sort.
Sad thing is if anybody remember PJ said car was finished all bar the Welding Work, it had 13 points classed as dangerous and if the car was driven it would have killed me.
What were the points though marcus ? I know PJ let you down with your car, but all his job to do was to replace your dead engine with your supplied engine.
we could start a " how many refusals" thread, winner wins a prize.
SWZ related
None of Shock Asorbers tightened up (Pj assured both myself and Helen seperatley that these would be torqued up)
O/S turbo bolts missing (Cant Guarantee these were not missing before)
Gaskets / sealant missing from both down pipes where they meet the turbo elbows (Exhaust was removed by PJ to fit engine)
Missing exhaust downpipe flange nut (As Above)
Front brake calipers are seized on (Due to length of time car was sat on axle stands)
Gear lever support bracket missing
Exhaust heat shield missing
Dump valves not connected ( no recircs either)
Air con outside sensor missing
Air leaks on engine plumbing
Idle speed incorrect set up
Throttle and cruise control cables too tight
Aiv supply pipes mixed up at throttle
Brake fluid below minimum limit
Fuel filter bracket bolts missing
Front shock absorbers both loose at top mounts (see point 1)
Cooler bracket insufficient (Cable tie job by SWZ)
Both front ABS Sensor wiring insecure resulting in ABS light not working.
NON SWZ related
Rear Discs excessiveley pitted
Fuel pipes Corroded
Brake Pipes Corroded
Offside & nearside subframe mounts excessive corroded
Offside & Nearside front and rear sills excessive corroded
Parking Brake has no reserve travel
No Main beam
Front reg plate too small
4 Wheel nuts missing
forgot the windscreen wiper blades need replacing too lol
bloody hell thats going to cost some dollar getting right isnt it?
Yep :(
Sorry but around half of those items are not even MOT test items!
I merged the mechanics report and Mot report together.
So what were the 48 refusals on the MOT test then? Sounds a bit over zealous to me tbh....
Yep Andy there are stuff on there which normally would not fail, once Mr MOT man finds 1 big fail he normally lists every single little near fail. 4 of the fails were due to missing wheel nuts, 4 on the list were down as items not tested (X9999).
Yeah you're right about that, once they fail it they tend to go mad on everything. Shame really :( Looks like another Z heading for breaking :(
Good luck with whatever you chose to do with it.
Nope car will be back on road in near future, i havent gone through lots of stress and crap to give up.
Glad to hear it Marcus! Far too many get broken these days for **** all reason. Good luck with it :)
yep, the one i did break (my silver one) was in better condition than the one I'm fixing LOL
Suprised you didn't pick up a box of bits rather than a car!
The bits would have fallen through the holes in the car if i did that LOL
Sorry to see its in such a bad way Marcus. When do you expect to have her back ?
Think Id just brake it and be done with it. Sorry to see this thread though bud
I'd be tempted to break it too. I know it is sad, but the cost of zeds these days, you could pick up a decent one for a steal.
Good luck with it anyway mate...
I think Marcus doesn't want to give in. Been messed about by the sounds of it, has a car that he's had to pretty much sacrifice. Gone too far with it now. Probably now wants to prove a point. I know I would
