I know this has been posted a while ago by Eric (lymon)
http://www.youtube.com/watch?v=8w8AAO6x2fs
It is seriously goddamn quick :bow: :bow: :shock: but finally somebody put up the spec on it:
Final specs on the car... here they are.
New set up, second build:
Built motor, different block, same heads as my first build
Twin Gt-3071's
Forged actuators w/20-24 psi springs
Custom SZ 3in. DP'S, test pipes, custom 3 inch cat back
PE 850 inj. w/ 300 degree fuel rails
RPS custom 4 puck clutch
Removed A/C system
751 Rwhp, 645 lbs Torque, stock pump ran out of fuel:)
Tuned @Specialty-Z 10/19/07
Look for octavian on twinturbo . net
He is the owner of this 300zx tt and was untuned th day he was doing all of these races although it was more than enough to compete with most the cars that day. It is using jwt 850 bb turbos otherwise known as the gt-35rs turbos. Should be making roughly 800+ to the wheels once tuned.
I just timed his last run, 80-150 just under 6.5 secs :shock: :bow:
He was a bit untidy hitting the limiter in 3rd and gearchange could have been a little faster so with a perfect run you could get that to under 6 secs.
Oh, and if all you ppl with manual gearboxes are thinking 'how's he getting such speeds?' his rev limiter is set at 8,000rpm now ;)
3rd gear stock is 110mph..............8,000rpm limiter is 122mph
4th gear stock is 143mph..............8,000rpm limiter is 159mph
Amazing machine! :bow:
christ what would the speed be on the limiter in fifth? sounds like it wouldnt take much longer to get there!!!
8,000 rpm on stock everything (manual transmission, diff, wheels & tyres) is 212mph according to my calculator :D
And I have to agree with you, it wouldn't take long to get there at all :shock:
surely that's not genuine? That speedo moved way too quick, both up and down?
Is the speedo in KMH?
Ivan
nope that's mph :) just a very quick car
800+hp at the wheels gets you acceleration like that :D
Good init? :) :bow:
Good init? :) :bow:
the only thing rapider would be the colour change of my pants lol :bow:
