This seems a fairly common upgrade on s13/s14 now and they are getting cheap £150 for calipers and discs .They are bigger nissan alloy calipers than the zed and bigger discs nearly 300mm staight bolt on fittment.and they take a standard s14/300zx pad as well.
:confused: What help/advice do you need???
Has anybody got them fitted and is there any diffrence over the stock system. ;)
Sorry mate, but im fairly positive that theyre exactly the same calipers, just different mounting to enable larger discs.
No they are definatly bigger than stock zed calipers .r33 gts/t use the same as well .
Having the same Pad fitment would indicate the same caliper to me, just with different mounts.
Larger disc would be of a benefit.
There deffinatly bigger calipers as ive seen some next to standard z calipers also i think pistons are bigger and its would have greater brakeing force as the caliper is set out towards the tyre more.
Take one of the pistons out and compare it to a zed piston
