water pipes rear of engine
What water pipes are their at the back of the engine apart from the matrix ones ?
Anyone got a got pic of the rear of engine too ?
vbgarage.php?do=thumb&width=175&id=4537
courtesy of markzx
courtesy of markzx
Have you got a magnifying glass? :rofl: :rofl: :rofl:
There are some that feed/return from the throttle body I think.
Here it is
Main water pipes other than heater matrix are the turbo coolant feeds and the plenum heater system.
Best to do a plenum bybass so that eliminates any potential problems there once the engine is back in.
I had a history of leaks and have ended up replacing every hose, Radiator and Water Pump as everything failed one by one as each previous failure was replaced with new.
Cost a bloody fortune doing it that way especially when the water pump failed and it ended up in a main dealers and I had to get a hire car !
