Ash spec zemulator
Hi All,
Does anyone have or have any experience with this ECU.
Ive read on here it is used alot in the states
Is it easy to use and can any tuner be able to work with it?
Andy recons its the dogs danglies
actualy, im gona get one of these, maybe they would do a group discount
Get a Nistune type 2 board...it does the same thing but better:
no external cables and boxes sticking out of your ECU and the realtime programming/monitoring is through the consult port
It also comes with better software
http://home.aanet.com.au/nistune/
i got lost with that after 20 seconds.
I looked at the Nistune site a little while ago - it does look like a good product.. Just how advanced are the capabilities of the stock ECU - I mean, in terms of things like: Ign. and Inj. adjustment based on coolant temp, air temp, TPS, and accelerator enrichment?
I'm guessing there's no air temp corrections of course, since we have no stock air temp sensor :)
(Good to see you're still here, Eric)
:D
a zemulator might not be a good option for you then either
For any realtime tuning application you need to have knowledge of how the ECU works and what each parameter/map does or stands for.
Our stock ECU is good enough for most applications when in the right hands ;)
I even use our ECU's to run tuned R33's on nowadays and prefer it over a PowerFC
Good to know :) I've found the PFC pretty easy to work with (though it does have it's little idiosyncrasies), so it sounds like the nistune would be a very good option when I finally get back to the Z.
I am in the process of trying to get one of these so would be happy to organise a GB on it and any of the other AshSpec products (alloy rad/intakes). Anyone interested let me know.
The Nistune looks impressive, and just £200 for Hardware and Software :cool:
I was looking to get the Zemulator once I have my Wideband sensor but after reading the manuals and other forums Im favouring the Nistune now.
