Active subwoofer
Just got this, it fits under the drivers or passenger seat, so instead of fillinf the whole car with bass you can also feel it under the seat.
Thought it would make a good alternative to those not relishing the job of a boot build.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=110217228912&ssPageName=STRK:MEWN:IT&ih=001
It weighs bugger all, it fits halfway under the seat but im not getting much volume from it at the mo, probably need to to wire it differently.
It weighs 4.4 KG and measures 340mmx22mmx71mm - and pushes out 70 watts RMS
Oh and mine's nice and loud :D
Phil I noticed you have two inputs to your sub, i only have one sub output from my stereo, did you use a splitter or something different?
Graham
Graham
No........ I used the L+R phono socket outputs from the back of my head unit :D
Did you not bother with the sub out then, is that why you got it louder?
No and maybe. Headunit is a Blaunpunkt Daytona BTW. :D
Did you also connect the hi inputs from your speaker outs.
Graham
Graham
No - just the phono outputs.
Ok cheers Phil, i will give that a go in the morning, Ive drained my battery at the mo from messing about with the dvd and headunit and trying to sort the sub out lol.
thanks for your help
No probs - hope you get it all sorted :D
