Changing to electric fan.
I'm finally going to fit my AMS radiator at the weekend and was thinking of converting from the Spitfire prop to an electric fan.What sort of Cfm will i need to keep the Zed cool? I'm thinking also about running without the rad cowl as i have no under tray and have a vented carbon bonnet.
http://www.z1motorsports.com/product_info.php?cPath=6_15&products_id=2454&osCsid=51728d558e4a99f76cda053db1b8e99d
Also will i need an expansion bottle ? I've been looking at this-
http://cgi.ebay.co.uk/ALLOY-RADIATOR-EXPANSION-HEADER-TANK-NISSAN-200SX-GOLF_W0QQitemZ350021048081QQihZ022QQcategoryZ72205QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Had a few bits off them and they have always been quality.
Your thoughts please :D
Looks like i'm going to be the Guinea pig then.LOL. :D
Ive just fitted this Radiator last week mate and its bloody good quality.. and BIG :). Just to let you know i had to trim down both of the "locating pins/legs" at the bottom of the radiator to get it in, unless your putting in the rad from underneith. Sorry I cant help with the electric fan or expansion bottle im affraid, just thought id put my 2p's worth in :D.
I saw you fit the rad last week and was going to PM you to see how it went but i can't cos youre not registered :headvswal
I'm very impresed with the rad though much better quality than the Koyo, and it is big aswell. :D
Sorry mate, I need to re-subscribe :).. Ive never seen the Koyo so cant really comment.
Yeah its very easy to fit, even for a novice like me.. Got a little worried at first as i saw afew pipes that were on the original radiator that wasnt on the new rad.. Checked underneith and those pipes were bunged up anyway so i have no idea what they was for. Altogether id say it took about 2 hours, But i like to take things steady and allow plenty of time and not to rush, Just make sure you have a file or saw handy to cut down those little legs at the bottom of the rad and it will slide straight down into the locating holes at the bottom :).
Regards
Rob
A 3000cfm fan setup would do the job.
I would suggest refitting undertray for Improved cooling !
Regards
Rob
Taa mate hopefully not too many problems. :D
I've been looking at fans half the size of that :eek: I was going to fit it to a stat.
Switch on temp - approx 95degC
Switch off temp - approx 85degC
Plus a manual overide.
It's only for fast road not for track use (yet).
Do i need an expansion tank?
Zcentre now do a electric fan, it will be very similar to mine which i'm pleased with they also come with a shroud to get more air onto the rad.
