Bonnet Stay/Strut
Hi guys.. As ive just bought and fitted a BIG AMS radiator from Z1 i am now left with no place for the bonnet stay to lay as i had to remove the old radiator brackets. So i am thinking about installing either 1 or 2 bonnet struts to hold up the bonnet.
My question is has anyone done this? And if so where did you get the gas struts from etc and how/where did you install it. :)
Any help is much appreciated
Rob
Much appreciated men.. Would the tailgait struts be up for this job?
Rob
We used a tailgate strut off an early Renault Megane hatchback as it,s not too long or powerful so it won,t smack in the chin on it,s way up . :D
If it,s over long it can strain the hinges.
Most of the screw in balls have an 8mm thread , i never did find out what the one i found with a 5mm thread was from :headvswal Rather than drilling out the already threaded insert in the inner wing to accept a rivnut , it would be easier to have the 8mm one tured down on a lathe and re-threaded to 5mm so it will screw staight in the inner wing with no mods , it,d only cost a drink at an engineering shop. :hyper: HTH
"SLAPPY & HAPPY,aka Boldy & MantaV8 told me how to do mine using a rear hatchback strutt off a Renault Megan. Works a treat and you only need one as there is no room on the other side.Picked mine up from main dealer.
I got mine from ceejay for £25 fitted, he has a special gun thing that fires a threaded rivit type thing.
few pics :)
Called a Rivnut gun mate,I have one! ;)
