j1mmytt 300zx journal
Im using this thread as a log for work carried out and finished.
Everything below was carried out by myself with help from club members,
Thanks guys :D
theres a few things on my list now.
1.need to adjust CAS timing. done, Thanks Andyp
2.find and stop oil leak. (rocker cover im thinking).seems to be cam/crankshaft seals. Done rear main seal
3.new engine mounts. in the post :) done
4.Find where the hell those wires from the aircon box are suppose to go. (should fix my heating problem, (only wants to come out hot) Done and dusted very chuffed the aircon is working :)
5.my hazard lights are still not working ive changed the switch twice now, starting to get very annoyed with that.
6.done wheel tracking.
7.Respray. Booked in :D Done
8.done Want to fit rear subframe poly bush collars??? in the post
9.tie rod poly bushings done
10.done new shocks in the post. fitted :)
11. Steering has slight play in it. maybe inner ball joints or outer. (bottom knuckle has play. one steering rack bush is deformed. Checked inner ball joints, they still have blue grease and look new, previous owner must has already changed them) steering rack bushings solved this.
12.done. front&rear lower arm poly bushings. in the post. fitted
13.Done Be rid of detting once and for all.
14.front&rear camber arms. in the post :) DONE
15.new steering rack bushings. in post. DONE
16. refurb calipers and paint silver. Done
17.fit braided brake hoses& brake brace. Done
18.Replace differential bushings done
19. ---- NA
20 jack up rear investigate location of knocking noise. Done
21. fit/spray stillen front splitter. CANCELLED
22a.nexus engine rebuild: underway woohoooo
Forged pistons (88mm oversize)
Forged rods
Cometic HG
reground crank
skim head
rebore cylinders
555 injectors
555 ecu Courtesy of Andy P
egr bypass
Oil pump
DONE
22b. fit rps max clutch. DONE
23.rebuild turbos. DONE
24 done NA
25. RR. currently on stock turbos running very rich 390fwhp DONE
26. Fit uprated bushings to rear traction arm and camber arms, in post. Done
27 fit Uk rear ARB DONE
28.fit tein ha's done
29. fit clutch booster done
30. Modify intercooler ducts. DONE
31. longer wheels studs DONE
32. roll arches DONE
33. 330mm discs DONE
34. Fit uprated smic DONE
35. paint timing covers/rocker covers/mild polish cas and rad pipes Done
36. Paint plenum DONE
37. fit nearside steering boot.
38. fit Steering uj Done
39. Replace Centre carrier bearing DONE
40. Replace rear nearside wheel bearing. Cancelled.
41. Fit uprated adjustable tension rods DONE
42. paint timing covers/plenum cover/balance bar/rocker covers/plenum Done
43.indiglo dials/chrome rings/stainless steel plate DONE
44. Conzult/get this thing running right. Done but still a few issues.
45. Install water injection system
46. Fit aftermarket gauges, oil pressure/water temp/boost gauge DONE
47. Fit crome hardpipes.
48. Underseal DONE
49.Fit water adapter and gauge/wire up oil pressure gauge. DONE
50. Fit new o2 sensors
51.fit carbon slam panels
52.fit crome z batt tie down/coil pack bolts/plenum&throttle body strips/stainless wing bolts. DONE
53.replace front tyres for mot.
54. JD 555's chip fitted.
55. fit solid steering pivot bush done
56. buy and fit bucket seats. DONE
57.Buy and fit ebc done
58.fit, innovate LC1 wideband kit. DONE
59. New fpr fitted,
. new rad cap
. new pvc hoses
. temp sensor and connector
59. purchase and fit lieghtwieght propshaft. Done
60. fit setrab 19 row oil cooler. DONE
61. adjust handbrake cable DONE
62. purchase and fit front strut brace. DONE
63. investigate high oil pressure (dodgy gauge maybe) DONE
64. purchase and fit Braided clutch line. GB DONE
65. Fit glowshift gauges, Oil temp/air,fuel/fuel pressure. DONE
65.Fit new Slave cylinder with Dot 3/4 fluid done
66. buy and fit uprated Rad with koyo bracket DONE
67.buy and fit series 2 ptu. Done
67.replace diff.
68.Refill diff oil "Kaaz lsd oil" Done... OMFG The old oil was as thick as glue.
69.Driftworks Hicas lock/z1 hicas hose bypass tube. in the post woohoo DONE
70.FIt & spray wings west rear skirt, car booked in for some spray work :D Done
71.need to replace rear lower shock bush grrr cant find poly anywhere :( DONE
71.replace pcv valves DONE
72.99 spec rear light conversion DONE
73. Fit spray 99spec front bumper Done
74.Put ABS on a switch. Done
75.full lightened pulley set.
76.Replace front pads (Performance friction 06) done
77.fit rear strut brace. DONE
78.replace front camber arm locking bolts with strengthened allen bolts
79.replace front 20mm spacers with 25mm fit rears with 20mm Cancelled
80.replace rear camber arms with driftworks arms. DONE
81. remove hicas bulb DONE
82. retrim interior DONE
83. fit 3 point harnesses DONE
84. replace tps DONE
85. spray and fit fog ducts. DONE
82.purchase and fit front/rear whiteline sway bars including front/rear adjustable drop links. DONE
83. spray and fit engine skins. DONE
84. Fit japspeed downpipes and de-cats DONE
85. fabricate brackets for porsche 996 calipers. DONE
86. fit porsche calipers and 328mm skyline discs currently using performance friction 06 compound pads. DONE
87. purchase and fit ultralite nurburgring wheels, 9.5j et20 all round. Done
88. 17inch track wheels with r888's 245/40/17 255/40/17 Done
89. Make and fit rear diffuser using perspex DONE
90.fit 3qrt accusump with EBC valve. Done
91. new wiring loom Done
DONE
92. GT25r turbo fitment:
ams manifolds
Z1 5 bolt stainless downpipes
hks actuators
DONE
93. remove A/C and all components DONE
94. HSD monotube coilovers 8kg 6kg spring rates fitted. Done
95. fit dba 5000 two piece front discs done
96. Make cold air ducts for discs. DONE
97. new front inner steering arm..... again. Done
98. fit new wiring harness, in post DONE
99. fit solid engine mounts with turbos, in post DONE
100. foam tank to stop fuel surge.
101. higher rated spark plugs
102. Q45 MAF setup. Requires 80mm-90mm reducer & 80mm metal pipe.
103. full JD remap
104. HID conversion Done
105. gtr33 rear brake setup, yellowstuff pads. done
106. Fit rear brake ducts.
107. Seal leaky targas. done
108. underseal, and seal all wheel arches.
109. driftworks rear traction rods
110. driftworks front lower arms Done
111.driftworks rear lower arms.
112. Customized adjustable front steering rod arms to compensate for lowering and bumpsteer. DONE
113. oil catch tank setup. Done
114. Godspeed IC ducting. Done
Car weighs in at 1480kg with 10litres or fuel.
1470kg with track wheels and tyres.
Please feel free to ask any questions regarding the above.
Edited by vodkashots
  • Replies 55
  • Views 3.8k
Ive spent a fortune this car better be worth it, i tell thee....
why dont you use the dedicated journel for your log!
ahh wheres that
ahh wheres that
click on user cp^^^^ then scroll to the bottom. that says "go to my journel"
...4.Find where the hell those wires from the aircon box are suppose to go. (should fix my heating problem, (only wants to come out hot) Done and dusted very chuffed the aircon is working :)....
Thanks Andy...
You're welcome bud LMAO ;)
Thanks Andy...
five little stars for andy***** :hyper: :bow: :rofl:
Well I got 7 for you (as long as the swear filter works lol)
Stick them up your arse and smoke them :rofl:
click on user cp^^^^ then scroll to the bottom. that says "go to my journal"
I think you'll find its JORNAL sexy boy :tongue:
I can't think of a 7 letter swear word ? give us a clue
WTF :shock:
:tongue:
Try B@stard PMSL
Try B@stard PMSL
Doh I was always shite at crosswords :confused: :D
WTF :shock:
:tongue:
Only way I could get a responce from 300zx.co.uk's answer to Daffyd - I am the only gay on the forum..........
and your calling me gay. im not the one calling other guys "sexy" :D
Nah I just put that because that's how your 'friends' refer to you, so you'd know it was for you
oi u lot jacking my thread :(
oh and thanks andy for finding the connector locations....
bunch oh wa****s theres a swear word :)
  • 3 months later...
Almost there... but the list is neverending and keeps growing.
  • 9 months later...
Heya Timmy,
Item 75.full lightened pulley set. - which ones did you opt for and where did ya get them sir?
Any hint of price for the set would be appreciated.
Best regards.
Andy
Heya Timmy,
errrr....that'll be Jimmy then...
Heya Timmy,
Best regards.
Andy
As item number 75 is still in black writing means i havent yet purchased them or fitted, BUT i will probably be buying from DTA, give him a shout in the traders forum.
DOH! Sorry Jimmy - my most humble apologies sir
Ah thats ok matey No worries. Youve just reminded me that ive got to spend more moenies now :D
I like the idea of posting up a list.
Nice one
Me too, its really helped me keep up to date with all my zed bits, i always refer back to this list to add and update whats done.
Alot of stuff i have done is not listed, i really should put it down.
I'm going to steal the idea ;)
Nice one, your car's come a long way in the last year or so!
