In memory of Mandy
Greddy smic's
Hi , another quick question. I have these smic's and happened to mention on here that I havent used all the fixing mounts on them and because of this is causing a boost leak ( I'm loosing a small amount of boost - probably 2 psi ) . happened to mention to a friend and he disagrees with this.. Does anyone on here know for sure?
All bolt holes in the greddy SMIC's must be pluged with bolts, whether you are using the holes as mounts or not.
Failure to plug all holes will result in a boost leak as the holes are drilled all the way to the internals of the SMIC.
what he said :)
