RichardS ·
Just bought some wheels tonight, however, i am not sure whether they will fit or not, or whether i can get away with spacers if they dont...
the rears are; 265, 35, 18 with an offset of 38...
the fronts are; 235, 40 18 with an offset of 52...
i think the rears will fit, the fronts i am not to sure about, any advise please...
thanks, Dan
