Power to PAX footwell on series 1
I've got, 'fingers crossed'. a LHD series 1 subframe coming my way which I am using on my passenger side to retro-fit electric pax seat.
Is there power in that footwell like there is on the drivers' side or will I have to run some power to it?
cheers
no, You will need to run power to it. Just a Positive and earth it to the floor. Make sure you use thick enough gauge wiring.
Thanks Dave, would it be just a case of running two spurs from the existing supply to the drivers side and run them underneath the the centre console under the carpet?
When i took my non electric recaros out and replaced them with heated leathers the electric pax side plugged straight in it was the drivers side that was a pain with different connectors
