Finally got the car through the mot (cheers andy duff for advising on turning the afc down to get through spot on it worked!!! cheers) took it to the rollers to to get remaped after playing with the afc. This is where the problem started
Â
1. When we tried to boost up the car over 12 psi the car wouldnt hold boost and was jumping up and down 1 psi but was fine up to 9-10 psi so i got the guy set it at stock boost which i believe is 7 psi it made 324 fwbhp at this settingi dont quite no how ??? and made 377 @ 12.7 psi 5500 rpm where the guy lifted off because of this psi jump . It has bigger turbos and possibly injectors (because at 12 psi the afc had loads more to go ).How did it make such high bhp at stock boost ??? Do the larger turbos make that much difference ??? Also what could be the problems associated with this psi jump ???
Â
2. On the last run one of the cooloant hoses gave out one of the ones at the front of the engine that go between the cam covers.Now im worried ive blown a head gasket the car didnt over heat ive heard of pipes bursting before and its resulted in a hg problems how will i know if it is a head gasket what test is there i can do ???
Â
Â
Â
regards jim
