- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Please help? I'm having a few issues with my 300zx TT. Where do I start!
1. I’m having a problem where the speedo drops out and the steering gets heavy and it doesn’t change gear, etc. I replaced the Speed sensor but it still happens (Mainly when it’s wet). At times it’s like it when I start the car and I have to have Hold switched on to get it to change into second gear. I connected OBD Tech Scan to the car whilst driving and noticed that when the speedo drops out the ECU is still reading the correct speed?? :confused: . I spoke to Zed World (Got it booked in for March) and they suggested it may be the instrumental panel? Any other ideas?
2. Problems starting the car (Most of the time). When I first start it up it revs up and starts to judder, the juddering get worse then it cuts out, if I then restart it strait after it usually starts fine? When it is juddering if I step on the accelerator the car just cuts out?
3. The car is using tones of petrol! On the weekend I put £30 in the tank drove to Amphill and back which is around a 50 - 55 mile round trip and the tank was almost empty on my return. I was booting it on the return trip, but still 30 quids worth???
Other Info which may help... I have had OBD Tech Scan hooked up and noticed my bank1s (Fuel section) are running RICH... My o2 Sensor is bouncing between 0 and 1000 every second or so... also I have a hole in my exhaust which I hope to get patched soon.
Would it be any use to record data with OBD Tech Scan and post it up (I have no idea how to read the data)??
Any help on the above would be much appreciated. Thanks
